Hi’ya all,
I am new to Lightburn but not new to cnc machines, just Lightburn and its idiosyncrasies, namely the camera and its relation to the work area. I use other machines that use camera overlays. Some are diy lasers and some manufactured i.e. XTool.
Issue is between me, Ortur Laser Master 3 with extensions 40w, and Lightburn 2.x (Most likely I am the issue and I can learn, ish).
Okay I did the camera setup all 3 steps, no big deal after a bunch of error trials approaching Groundhog Day repeat-repeating until I uninstalled Lightburn and reinstalled it. I open my piece to engrave, get my work piece arranged in the bed, home, set home, use absolute origin, update the camera overlay image and align my graphic to be engraved. Easy-peasy! I preview the paths and then run the frame… The frame seems to occasionally and marginally correctly frame work piece. I proceed to return to origin, home, re-frame test again. Alas the frame doesn’t travel the same path as the 1st frame. Hence I return to origin, check for my 0,0,0,0 and home still 0,0,0,0. Yep again I frame! Nope, not the same path as the previous framing. Okay shutdown Lightburn and the laser machine, restart the engraving machine and then Lightburn and home and 0,0,0,0, load project, update overlay image, run the frame, it’s close but still not matching the placement of the material and the engraving image. Return to home, I move the material and re-run frame, closer and closer each time. Okay I think it’s gotta’ be this time after my latest material adjustment…frame again. Now I am silently screaming inside and laugh at the absurdity of it all. Try again tomorrow, go read up on the interwebs about Lightburn, camera setup and alignment, lens calibration and overlays again. This is where you can start part way through the second paragraph all over again; day three. Same pattern, same issue. I am tenacious and possibly stubborn. I checked the belts tension and alignments, it homes and zeros without issue. My machines home origin is lower left, as is my absolute origin. I triple checked my start position [green dot]; absolute 0,0,0,0; not user, not current and the laser moves and starts from the correct position, it’s the framing that seems to arbitrarily change; hence checking the belts, homing, and origins. I am baffled within my tunnel vision idea of overlay image + graphic + material + machine = framing disco party, all over the place. I am sure this could have been shorter, maybe next time, we’ll see.
Looking forward to the interwebs knowledge and experience.
A
