I need help and hoping someone can point me in the right direction. For some reason my images are wide. And the height and are not measuring out right. Something is definitely off. Im using lightburn.
Check your firmware settings. The correct values are described here: Firmware Update & Settings - Diode Laser Wiki
If you are new to the Sculpfun lasers, I recommend starting here as well: Quick Start & Overview - Diode Laser Wiki
Make sure you have the right size set in the device settings.
