Help with Lasering
Hi all! Can someone tell me how to fix this? It is supposed to laser how it shows on the left, but I hit start and noticed that it was not lasering like that at all, so I pulled up the preview and it shows this! How do I fix this problem to make it laser the correct way?
Hey @Hannah7685
The Preview is the important clue here — that’s what LightBurn is actually going to send to the laser.
The widely spaced horizontal lines usually mean the image layer has a very large Line Interval / very low DPI setting. Double-click the image (or Fill) layer in Cuts/Layers and check the Line Interval. If you’re working in inches, try something around 0.004 in as a starting point, which is about 250 DPI, then check Preview again.
I’d also check the Image Mode. For this kind of black logo artwork, Threshold is probably the best place to start.
Once the line interval and image mode are corrected, the Preview should look much closer to what you’re seeing on the workspace. Otherwise lets see your Cut/Layers settings, please?
HI Hannah
What is your ‘Line Interval’ set to…looks like it’s set very Low. ‘Lines per Inch’.
0.00 = Lines just meeting. Larger numbers mean scan Lines further apart.
