How do I remove these 4 Nodes so I can extend the line horizontally so I can get rid of the 2 vertical lines?
Mouse over the node and press the “D” key. Sometimes you need to click the node. Also if you hover over the edit node tool it will pop up a help window.
If I delete the Nodes it doesn’t solve the problem. The vertical lines are not removed.
This is what it looks like if I just delete them. I need the 2 circled nodes to connect to each other and then get rid of the vertical line below them,
Hover over the line, press D or B then D.
Thanks! Hovering over the line and pressing D worked
