Help with setting up my camera
Ok here is my problem I do the calibration on the camera fine but when I go to set up for the alignment laser does this big almost the whole frame of the 26x40 not just a 8x11 page any ideas as to what I have set wrong this all started with the last update befor that last update it worked fine
Change the scaling! There is a scaling factor when you get tot the last part of the calibration where it shows the 4 numbered crosshairs with power and height setting!
Will try that thanks
