Hello,
I try to engrave a QRCode with my China-Laser from Sovol (must be the same as the Creality one)
sorry, you have to google by yourself, because of the 2-Post-Rule. Type (Sovol laser module)
The Printer is a Svol SV02 and Lightburn detects a GBRL M3 (1.1e or earlier) so I added manually a Marlin printer.(because with the GBRL he will do the movements, but no Laserbeam (maybe its because I need the M106 instead of the M8).
What did I wrong? What else do you need at Information?
Can no one help me?
Do you need more information to help me?
In the meantime, I noticed that the edge of the qrcode is very clean, but inside it is totally warped. You can see that at the 2.picture.
Could this be a clue to the error?
I really need help. it’s for my work.
Edit: can i add the M106 command to the GRBL printer? that is, tell it to use only M106?
My SV02 runs with Marlin 2.0.
The funny thing is, that I have to do it that way.
Without autodetecting, Lightburn will not move the printer head.
I have to switch to GRBL to move in position, than I have to switch to Marlin and create the gcode.
