I am trying to weld this word to the outer edge of the ornament and its not working for me. I am having a brain fart.
Make sure each object is a path and the circle of the ornament is joined. Select the word and the circle and press control/command and B to get the Boolean tool. If you don’t get the Boolean tool, then each item is not yet ready to join up.
I did that but the word Emery just disappears
Did you weld or did you use the Boolean tools?
Weld will not work in this case.
I used Union, not weld
