PirateLady
(Oedse van der Laan)
1
wie kan mij uitleggen hoe je gaatjes maakt in leer via lightburn om leer aan elkaar te naaien
Can someone explain to me how to create holes in leather using LightBurn, so that the leather pieces can be stitched together?
MikeyH
(Mike Hembrey)
2
- Create one circle the size you want the hole to be.
- Use the Array Tool to make a string of copies. Set your spacing between holes.
- Use CTRL-D to make a copy of the holes (they will be grouped) and place it outside the design grid for future use.
- Place the holes along the edge of your first piece of material in your Lightburn design grid.
- Use CTRL-D to make a duplicate of the holes and align it on the adjoining piece of material.
If this did not make sense to you, it may help if you review the Lightburn documentation.
parsec
(FerAS)
3
You can also use Perforation Mode.
ednisley
(Ed Nisley)
4
Be positive the leather does not contain chrome compounds from the tanning process:
Hexavalent chromium is nasty stuff:
Kuth
(Luis Jardim)
5
Coincidentally, I just saw a 2000 film about this yesterday: “Erin Brockovich”.
PirateLady
6
Dankjewel voor je uitleg!! Het werkt!!
