hola mi lightburn se puso muy grande y no se como ponerlo en tamaño normal
Hi, my Lightburn has become very large and I don’t know how to put it back to normal size.
If it happened with the 2.x.xx upgrade, it is due to how Lightburn now works with Windows. You can try these steps:
- Maximize the LB window. You can use WinKey + UpArrow to do this.
- In LB, open Window → Reset to Default Layout.
- It may help if you turn on Auto-hide for the Windows Task Bar.
- In Edit → Settings → Display tab, you can adjust your icon and text sizes. Turning off Enable High DPI Scaling may also help.
