Since the I updated this week, I’ve found a lot of the designs I’m importing are filling in the holes in the text. As an example, the letter O, the hole is also filled in. I’ve cut and engraved these designs many times and I haven’t come across this issue. Is it a setting that has changed that I can easily fix? Or is this a problem with the software?
There will, though right now if you ungroup and select your artwork, go to Edit > Close Paths it should work.
The issue is that the source paths aren’t actually closed / sealed from the drawing software, though LightBurn’s cut builder dealt with it. We recently changed some of the code that handles filled drawing, and didn’t include that additional check. It’s been added to the next update which will be coming shortly.
