Home always X0Y0
I want my homing position top left corner. I have set the origin as such but laser return bottom left corner how kan I change that. I’m new to light burn and new to laser.
You can tell the laser to END at a different location than HOME. Change the RETURN TO FINISH POSITION coords to your desire. Sounds like you wantx= 0,y=390?
Thanks but I stuffed up my settings so much I cant get the laser to respond at . Alarm out of limits Let me just experiment more
If your laser has limit switches I don’t think you have a choice. Most lasers home to bottom left. But you can set the Return to Finish Position wherever you want. That is where the laser goes after the job is done. You dont say what model of laser you have,
