Hi - I’m running Lightburn on a 60 Watt OM Tech Co2 Laser with a Ruida 644XG Controller.
When I use Current Position setting in Lightburn the machine frames correctly but when I run the engraving and it finishes the machine runs to home instead of the current position starting point is there a setting I should be looking to change this? I know that in the past it would run to current position setting.
All I can find is this setting in “Device Settings”
Enter the current position starting point and it will return to that location.
Maybe there is a setting somewhere else but this would work for the current project you are working on.
Hi Craig,
The finish position is handled by a setting on your controller. In LightBurn, with your laser on and connected, try going to ‘Edit’ > ‘Machine Settings’ and setting your ‘Return Position’ to ‘Origin’.
Thank you for the information
Thank you for the information - I will try that tonight
That fixed the issue it was set at absolute origin and I changed it to origin works as it should now
Thanks again
This is only visible in a grbl system. He is on a Ruida…
Thanx Jack. Wasn’t aware of that.
No perspiration… I’d be nice to know it all…
I thought you did.
