# Homing cycle is not enabled in your Grbl settings
**URL:** <https://forum.lightburnsoftware.com/t/homing-cycle-is-not-enabled-in-your-grbl-settings/25718>\
**Created:** [November 11, 2020, 7:52pm UTC](https://forum.lightburnsoftware.com/t/homing-cycle-is-not-enabled-in-your-grbl-settings/25718 "2020-11-11T19:52:43Z")\
**Showing post:** 17
**Author:** ![LightBurn](https://forum.lightburnsoftware.com/user_avatar/forum.lightburnsoftware.com/lightburn/32/75577_2.png) [@LightBurn](https://forum.lightburnsoftware.com/u/LightBurn)\
**Post date:** [November 21, 2020, 5:03pm UTC](https://forum.lightburnsoftware.com/t/homing-cycle-is-not-enabled-in-your-grbl-settings/25718/17 "2020-11-21T17:03:59Z")
> [@How do I turn on my diode at low power to focus it or frame a job?](https://forum.lightburnsoftware.com/t/how-do-i-turn-on-my-diode-at-low-power-to-focus-it-or-frame-a-job/10520):
> Diode lasers often don’t have a red-dot pointer like CO2 lasers do, so it is often useful to enable them at low power for focusing or framing. (Please do NOT do this if you have a CO2 laser, as the beam is invisible and this could blind you or start a fire) In LightBurn, go to Edit \> Device Settings, or click here: [image] Turn on the ‘Enable Laser Fire Button’ switch (make it green): Quit LightBurn and re-run it. You will now have two new controls in the Move window. A …
_[View the full topic](https://forum.lightburnsoftware.com/t/homing-cycle-is-not-enabled-in-your-grbl-settings/25718)._
