Im having issues with my new creality 12w falcon platform engraver. When i hit home it comes into the left corner gets stuck there and tries to keep going creating a very annoying rummble. Also when it moves on the rail it makes noise as well. Granted the rails are painted it does get annoying. Any other falcon users having issues?
Something is likely impeding the homing switches from being actuated. Check X and Y separately. If you have mechanical switches you should be able to hear and feel them being actuated when the laser head reaches the front left. If you have proximity sensors there will be something that crosses the path the of the sensor.
If they are not actuating, check for anything physical that would prevent actuation and correct for it.
They are in fact actuating then likely a wiring issue.
