Homing problem please help
Hi, I recently installed Windows 11 on my laser pc, now when I press “Home” it doesn’t go to the correct position (it’s about 10 to 20mm out in both axes), the laser position on the screen shows that it is outside the working area. Is this a known problem please help? OLM3 Laser
It stops before hitting the limit switches?
Yes, but the OLM3 doesn’t have limit switches as such, the machine moves against hard stops, then it is home but not in my case, it is no where near the home position.
Would you be able to move head to center, and take a small video of the homing
Upload to youtube and post here
Also take image of your belt tensioners please
I will do later, I’m at work at the moment.
