Honeycomb Working Panel
Anyone have any experience on how to clean the residue of the honeycomb working panel.
try typing “clean honeycomb” in the search field, you will be amazed at the result :wink:
I take mine outside and use oven cleaner.
As a warning to people who have aluminum honeycomb, don’t use oven cleaner if that’s the case. The reaction is not pleasant.
True, or any other cleaner that contains caustic soda or lye.
It will also react with zinc coatings so galvanized and zinc-aluminum coated steel will eventually start to rust after a few cleanings with oven cleaner but not enough to really worry about.
