Hello
I have set up the Lightburn software and its chatting to my laser machine (yay!)… I have also gotten as far as to cut a rectangle.
Cutting text though… am sure I am missing a very simple step? I add the text… click START and it just sits in one spot?
Yet when I make a rectangle and start, off it goes…
Thanks so much
fred_dot_u
(fred ungewitter)
January 30, 2020, 11:38pm
2
If you can show a screen capture of your layer settings, it would be helpful. Check the layer for the text, ostensibly set to fill, and ensure that the output column has a tick. Use the preview button to see the results, which reduces waste in the long run.
Your operating system and a note that you are using an Emblaser 1 is also helpful, but probably not in this circumstance. My Emblaser is collecting dust since I got a super-zapper (CO2), so I can’t give you specific approach just yet.
Thank you, its an Emblaser 1. When I hit preview it plays the sequence ok, but the laser does nothing when I hit Start
fred_dot_u
(fred ungewitter)
January 31, 2020, 12:36am
5
One aspect of the E1 I can recall is that it is necessary to hold the laser button on the console until it flickers. Is that still a requirement for LB? I suspect that it is. When you were able to cut the rectangle, was that part of your workflow?
It also looks like you have debug drawing enabled (that’s the pink rectangles around everything). You can turn that off by clicking Edit > Debug Drawing.
I’m not familiar with any special ways the Emblaser 1 works, but Fred could easily be right.
I’ve debugged and still the same. Press start it moves to position then stops
I’m keen to purchase after the trial but not if I can’t cut text.
Blake
(Blake Bartlett)
January 31, 2020, 3:40pm
10
Did you cut the rectangle with absolute coordinates enabled?
The issue won’t likely be specific to text. Can you show a screen grab of what the console window says after you press Start to run the job?
I got the red dots off, here is a screenshot of the console window
Ok, that’s a good start. In LightBurn, click the ‘Save GCode’ button near the Start button, give it a filename that ends in .txt and then attach that file here so I can have a look.
TXT File
; LightBurn 0.9.09
; Emblaser 1 A4 device profile, absolute coords
G00 G17 G40 G21 G54
G90
M4
; Cut @ 50 mm/sec, 65% power
M8
G0X44.45Y111.82
G1X44.78Y111.75S650F3000
G1X45.11Y111.71
G1X45.59Y111.69
G1X46.06Y111.7
G1X46.7Y111.77
G1X47.34Y111.89
G1X47.02Y113.82
G1X46.67Y113.77
G1X46.32Y113.74
G1X45.97
G1X45.63Y113.78
G1X45.46Y113.83
G1X45.3Y113.9
G1X45.17Y114
G1X45.05Y114.12
G1X44.96Y114.26
G1X44.89Y114.42
G1X44.85Y114.58
G1Y114.76
G1X44.82Y115.03
G1X44.81Y115.31
G1Y123.11
G1X47.02
G1Y124.82
G1X44.81
G1Y129.35
G1X42.63Y128.03
G1Y124.82
G1X41.02
G1Y123.11
G1X42.63
G1Y115.65
G1Y115.1
G1X42.65Y114.55
G1X42.7Y114
G1X42.78Y113.45
G1X42.83Y113.23
G1X42.92Y113.02
G1X43.02Y112.83
G1X43.14Y112.64
G1X43.29Y112.47
G1X43.45Y112.32
G1X43.63Y112.18
G1X43.83Y112.07
G1X44.13Y111.93
G1X44.45Y111.82
G1X44.78Y111.75
G1X45.11Y111.71
G1X45.59Y111.69
G1X46.06Y111.7
G1X46.7Y111.77
G1X47.34Y111.89
G1X47.02Y113.82
G1X46.67Y113.77
G1X46.32Y113.74
G1X45.97
G1X45.63Y113.78
G1X45.46Y113.83
G1X45.3Y113.9
G1X45.17Y114
G1X45.05Y114.12
G1X44.96Y114.26
G1X44.89Y114.42
G1X44.85Y114.58
G1Y114.76
G1X44.82Y115.03
G1X44.81Y115.31
G1Y123.11
G1X47.02
G1Y124.82
G1X44.81
G1Y129.35
G1X42.63Y128.03
G1Y124.82
G1X41.02
G1Y123.11
G1X42.63
G1Y115.65
G1Y115.1
G1X42.65Y114.55
G1X42.7Y114
G1X42.78Y113.45
G1X42.83Y113.23
G1X42.92Y113.02
G1X43.02Y112.83
G1X43.14Y112.64
G1X43.29Y112.47
G1X43.45Y112.32
G1X43.63Y112.18
G1X43.83Y112.07
G1X44.13Y111.93
G1X44.45Y111.82
G0X50.83Y119.58
G1X50.89Y120.15
G1X51.03Y120.71
G1X51.23Y121.25
G1X51.51Y121.75
G1X51.82Y122.14
G1X52.18Y122.48
G1X52.57Y122.77
G1X53Y123
G1X53.46Y123.17
G1X53.93Y123.27
G1X54.42Y123.31
G1X54.92Y123.29
G1X55.26Y123.24
G1X55.59Y123.16
G1X55.9Y123.05
G1X56.21Y122.9
G1X56.49Y122.73
G1X56.76Y122.52
G1X57.01Y122.29
G1X57.23Y122.04
G1X57.49Y121.65
G1X57.7Y121.24
G1X57.86Y120.8
G1X57.96Y120.35
G1X58.03Y119.97
G1X58.07Y119.58
G1X50.83
G1X50.89Y120.15
G1X51.03Y120.71
G1X51.23Y121.25
G1X51.51Y121.75
G1X51.82Y122.14
G1X52.18Y122.48
G1X52.57Y122.77
G1X53Y123
G1X53.46Y123.17
G1X53.93Y123.27
G1X54.42Y123.31
G1X54.92Y123.29
G1X55.26Y123.24
G1X55.59Y123.16
G1X55.9Y123.05
G1X56.21Y122.9
G1X56.49Y122.73
G1X56.76Y122.52
G1X57.01Y122.29
G1X57.23Y122.04
G1X57.49Y121.65
G1X57.7Y121.24
G1X57.86Y120.8
G1X57.96Y120.35
G1X58.03Y119.97
G1X58.07Y119.58
G1X50.83
G0X50.71Y117.78
G1X60.38
G1X60.39Y118.65
G1X60.33Y119.52
G1X60.19Y120.37
G1X59.98Y121.21
G1X59.82Y121.65
G1X59.63Y122.07
G1X59.41Y122.47
G1X59.16Y122.84
G1X58.88Y123.19
G1X58.57Y123.52
G1X58.24Y123.82
G1X57.89Y124.09
G1X57.52Y124.33
G1X57.13Y124.54
G1X56.72Y124.73
G1X56.3Y124.88
G1X55.86Y124.99
G1X55.41Y125.07
G1X54.95Y125.11
G1X54.49
G1X53.99
G1X53.5Y125.06
G1X53.01Y124.97
G1X52.54Y124.84
G1X52.07Y124.67
G1X51.63Y124.46
G1X51.2Y124.21
G1X50.79Y123.93
G1X50.39Y123.58
G1X50.04Y123.21
G1X49.71Y122.81
G1X49.43Y122.39
G1X49.18Y121.94
G1X48.97Y121.47
G1X48.8Y120.98
G1X48.67Y120.48
G1X48.55Y119.85
G1X48.47Y119.21
G1X48.43Y118.58
G1Y117.94
G1X48.48Y117.3
G1X48.56Y116.67
G1X48.69Y116.04
G1X48.85Y115.42
G1X48.99Y115.04
G1X49.16Y114.67
G1X49.35Y114.31
G1X49.57Y113.98
G1X49.81Y113.66
G1X50.07Y113.36
G1X50.35Y113.08
G1X50.65Y112.82
G1X50.97Y112.58
G1X51.3Y112.37
G1X51.65Y112.18
G1X52.02Y112.02
G1X52.39Y111.88
G1X52.78Y111.77
G1X53.18Y111.68
G1X53.59Y111.63
G1X54.37Y111.57
G1X55.16Y111.58
G1X55.89Y111.66
G1X56.6Y111.82
G1X57.29Y112.07
G1X57.95Y112.41
G1X58.33Y112.67
G1X58.68Y112.97
G1X59.01Y113.29
G1X59.31Y113.64
G1X59.57Y114.02
G1X59.8Y114.42
G1X60Y114.83
G1X60.16Y115.27
G1X60.31Y115.75
G1X58.04Y116.03
G1X57.84Y115.51
G1X57.59Y115.03
G1X57.27Y114.58
G1X56.9Y114.17
G1X56.65Y113.98
G1X56.39Y113.82
G1X56.12Y113.68
G1X55.84Y113.56
G1X55.54Y113.47
G1X55.24Y113.41
G1X54.94Y113.38
G1X54.63
G1X54.09Y113.4
G1X53.57Y113.51
G1X53.07Y113.69
G1X52.61Y113.93
G1X52.19Y114.24
G1X51.82Y114.61
G1X51.49Y115.03
G1X51.23Y115.5
G1X51.02Y116.05
G1X50.86Y116.62
G1X50.76Y117.19
G1X50.71Y117.78
G1X60.38
G1X60.39Y118.65
G1X60.33Y119.52
G1X60.19Y120.37
G1X59.98Y121.21
G1X59.82Y121.65
G1X59.63Y122.07
G1X59.41Y122.47
G1X59.16Y122.84
G1X58.88Y123.19
G1X58.57Y123.52
G1X58.24Y123.82
G1X57.89Y124.09
G1X57.52Y124.33
G1X57.13Y124.54
G1X56.72Y124.73
G1X56.3Y124.88
G1X55.86Y124.99
G1X55.41Y125.07
G1X54.95Y125.11
G1X54.49
G1X53.99
G1X53.5Y125.06
G1X53.01Y124.97
G1X52.54Y124.84
G1X52.07Y124.67
G1X51.63Y124.46
G1X51.2Y124.21
G1X50.79Y123.93
G1X50.39Y123.58
G1X50.04Y123.21
G1X49.71Y122.81
G1X49.43Y122.39
G1X49.18Y121.94
G1X48.97Y121.47
G1X48.8Y120.98
G1X48.67Y120.48
G1X48.55Y119.85
G1X48.47Y119.21
G1X48.43Y118.58
G1Y117.94
G1X48.48Y117.3
G1X48.56Y116.67
G1X48.69Y116.04
G1X48.85Y115.42
G1X48.99Y115.04
G1X49.16Y114.67
G1X49.35Y114.31
G1X49.57Y113.98
G1X49.81Y113.66
G1X50.07Y113.36
G1X50.35Y113.08
G1X50.65Y112.82
G1X50.97Y112.58
G1X51.3Y112.37
G1X51.65Y112.18
G1X52.02Y112.02
G1X52.39Y111.88
G1X52.78Y111.77
G1X53.18Y111.68
G1X53.59Y111.63
G1X54.37Y111.57
G1X55.16Y111.58
G1X55.89Y111.66
G1X56.6Y111.82
G1X57.29Y112.07
G1X57.95Y112.41
G1X58.33Y112.67
G1X58.68Y112.97
G1X59.01Y113.29
G1X59.31Y113.64
G1X59.57Y114.02
G1X59.8Y114.42
G1X60Y114.83
G1X60.16Y115.27
G1X60.31Y115.75
G1X58.04Y116.03
G1X57.84Y115.51
G1X57.59Y115.03
G1X57.27Y114.58
G1X56.9Y114.17
G1X56.65Y113.98
G1X56.39Y113.82
G1X56.12Y113.68
G1X55.84Y113.56
G1X55.54Y113.47
G1X55.24Y113.41
G1X54.94Y113.38
G1X54.63
G1X54.09Y113.4
G1X53.57Y113.51
G1X53.07Y113.69
G1X52.61Y113.93
G1X52.19Y114.24
G1X51.82Y114.61
G1X51.49Y115.03
G1X51.23Y115.5
G1X51.02Y116.05
G1X50.86Y116.62
G1X50.76Y117.19
G1X50.71Y117.78
G0X62.19Y115.73
G1X62.34Y115.05
G1X62.57Y114.39
G1X62.89Y113.78
G1X63.28Y113.21
G1X63.51Y112.96
G1X63.75Y112.73
G1X64.01Y112.52
G1X64.28Y112.34
G1X64.57Y112.17
G1X64.87Y112.03
G1X65.18Y111.92
G1X65.51Y111.83
G1X66.15Y111.69
G1X66.8Y111.61
G1X67.46Y111.57
G1X68.11
G1X68.54Y111.6
G1X68.96Y111.65
G1X69.37Y111.73
G1X69.77Y111.84
G1X70.17Y111.98
G1X70.56Y112.15
G1X70.93Y112.34
G1X71.3Y112.56
G1X71.77Y112.93
G1X72.16Y113.37
G1X72.48Y113.86
G1X72.73Y114.38
G1X72.88Y114.94
G1X72.96Y115.52
G1X72.94Y116.11
G1X72.83Y116.7
G1X72.7Y117.04
G1X72.55Y117.35
G1X72.36Y117.64
G1X72.14Y117.91
G1X71.89Y118.16
G1X71.61Y118.37
G1X71.31Y118.55
G1X70.99Y118.7
G1X70.09Y119.02
G1X69.19Y119.32
G1X68.27Y119.58
G1X67.35Y119.82
G1X66.57Y120.04
G1X65.79Y120.28
G1X65.46Y120.43
G1X65.17Y120.64
G1X64.93Y120.91
G1X64.75Y121.23
G1X64.7Y121.43
G1X64.68Y121.63
G1X64.7Y121.83
G1X64.74Y122.02
G1X64.81Y122.2
G1X64.91Y122.38
G1X65.03Y122.54
G1X65.18Y122.68
G1X65.4Y122.86
G1X65.65Y123
G1X65.91Y123.11
G1X66.19Y123.18
G1X66.8Y123.28
G1X67.41Y123.31
G1X68.02Y123.27
G1X68.63Y123.17
G1X68.96Y123.05
G1X69.27Y122.89
G1X69.54Y122.68
G1X69.78Y122.44
G1X69.99Y122.16
G1X70.15Y121.86
G1X70.26Y121.53
G1X70.32Y121.18
G1X72.47Y121.48
G1X72.37Y122.01
G1X72.21Y122.52
G1X71.99Y123.02
G1X71.71Y123.49
G1X71.41Y123.82
G1X71.07Y124.11
G1X70.7Y124.36
G1X70.29Y124.56
G1X69.57Y124.81
G1X68.84Y124.99
G1X68.09Y125.09
G1X67.33Y125.12
G1X66.55Y125.08
G1X65.78Y124.95
G1X65.03Y124.72
G1X64.31Y124.4
G1X64.02Y124.2
G1X63.74Y123.98
G1X63.49Y123.74
G1X63.27Y123.47
G1X63.07Y123.18
G1X62.9Y122.88
G1X62.76Y122.55
G1X62.66Y122.21
G1X62.58Y121.8
G1X62.55Y121.38
G1X62.58Y120.96
G1X62.66Y120.55
G1X62.79Y120.16
G1X62.97Y119.78
G1X63.19Y119.43
G1X63.47Y119.1
G1X63.81Y118.8
G1X64.19Y118.55
G1X64.59Y118.34
G1X65.02Y118.17
G1X65.91Y117.88
G1X66.81Y117.61
G1X67.71Y117.36
G1X68.62Y117.13
G1X68.99Y117.04
G1X69.35Y116.91
G1X69.7Y116.77
G1X70.05Y116.61
G1X70.22Y116.49
G1X70.36Y116.35
G1X70.48Y116.19
G1X70.58Y116.02
G1X70.65Y115.83
G1X70.69Y115.63
G1X70.71Y115.43
G1X70.69Y115.23
G1X70.63Y114.99
G1X70.55Y114.75
G1X70.44Y114.54
G1X70.31Y114.33
G1X70.15Y114.15
G1X69.97Y113.98
G1X69.77Y113.84
G1X69.55Y113.72
G1X69.11Y113.56
G1X68.66Y113.44
G1X68.19Y113.38
G1X67.72
G1X67.17Y113.39
G1X66.62Y113.48
G1X66.1Y113.65
G1X65.6Y113.9
G1X65.38Y114.08
G1X65.17Y114.27
G1X64.99Y114.48
G1X64.83Y114.71
G1X64.69Y114.95
G1X64.57Y115.21
G1X64.48Y115.47
G1X64.42Y115.75
G1X64.36Y116.07
G1X62.19Y115.73
G1X62.34Y115.05
G1X62.57Y114.39
G1X62.89Y113.78
G1X63.28Y113.21
G1X63.51Y112.96
G1X63.75Y112.73
G1X64.01Y112.52
G1X64.28Y112.34
G1X64.57Y112.17
G1X64.87Y112.03
G1X65.18Y111.92
G1X65.51Y111.83
G1X66.15Y111.69
G1X66.8Y111.61
G1X67.46Y111.57
G1X68.11
G1X68.54Y111.6
G1X68.96Y111.65
G1X69.37Y111.73
G1X69.77Y111.84
G1X70.17Y111.98
G1X70.56Y112.15
G1X70.93Y112.34
G1X71.3Y112.56
G1X71.77Y112.93
G1X72.16Y113.37
G1X72.48Y113.86
G1X72.73Y114.38
G1X72.88Y114.94
G1X72.96Y115.52
G1X72.94Y116.11
G1X72.83Y116.7
G1X72.7Y117.04
G1X72.55Y117.35
G1X72.36Y117.64
G1X72.14Y117.91
G1X71.89Y118.16
G1X71.61Y118.37
G1X71.31Y118.55
G1X70.99Y118.7
G1X70.09Y119.02
G1X69.19Y119.32
G1X68.27Y119.58
G1X67.35Y119.82
G1X66.57Y120.04
G1X65.79Y120.28
G1X65.46Y120.43
G1X65.17Y120.64
G1X64.93Y120.91
G1X64.75Y121.23
G1X64.7Y121.43
G1X64.68Y121.63
G1X64.7Y121.83
G1X64.74Y122.02
G1X64.81Y122.2
G1X64.91Y122.38
G1X65.03Y122.54
G1X65.18Y122.68
G1X65.4Y122.86
G1X65.65Y123
G1X65.91Y123.11
G1X66.19Y123.18
G1X66.8Y123.28
G1X67.41Y123.31
G1X68.02Y123.27
G1X68.63Y123.17
G1X68.96Y123.05
G1X69.27Y122.89
G1X69.54Y122.68
G1X69.78Y122.44
G1X69.99Y122.16
G1X70.15Y121.86
G1X70.26Y121.53
G1X70.32Y121.18
G1X72.47Y121.48
G1X72.37Y122.01
G1X72.21Y122.52
G1X71.99Y123.02
G1X71.71Y123.49
G1X71.41Y123.82
G1X71.07Y124.11
G1X70.7Y124.36
G1X70.29Y124.56
G1X69.57Y124.81
G1X68.84Y124.99
G1X68.09Y125.09
G1X67.33Y125.12
G1X66.55Y125.08
G1X65.78Y124.95
G1X65.03Y124.72
G1X64.31Y124.4
G1X64.02Y124.2
G1X63.74Y123.98
G1X63.49Y123.74
G1X63.27Y123.47
G1X63.07Y123.18
G1X62.9Y122.88
G1X62.76Y122.55
G1X62.66Y122.21
G1X62.58Y121.8
G1X62.55Y121.38
G1X62.58Y120.96
G1X62.66Y120.55
G1X62.79Y120.16
G1X62.97Y119.78
G1X63.19Y119.43
G1X63.47Y119.1
G1X63.81Y118.8
G1X64.19Y118.55
G1X64.59Y118.34
G1X65.02Y118.17
G1X65.91Y117.88
G1X66.81Y117.61
G1X67.71Y117.36
G1X68.62Y117.13
G1X68.99Y117.04
G1X69.35Y116.91
G1X69.7Y116.77
G1X70.05Y116.61
G1X70.22Y116.49
G1X70.36Y116.35
G1X70.48Y116.19
G1X70.58Y116.02
G1X70.65Y115.83
G1X70.69Y115.63
G1X70.71Y115.43
G1X70.69Y115.23
G1X70.63Y114.99
G1X70.55Y114.75
G1X70.44Y114.54
G1X70.31Y114.33
G1X70.15Y114.15
G1X69.97Y113.98
G1X69.77Y113.84
G1X69.55Y113.72
G1X69.11Y113.56
G1X68.66Y113.44
G1X68.19Y113.38
G1X67.72
G1X67.17Y113.39
G1X66.62Y113.48
G1X66.1Y113.65
G1X65.6Y113.9
G1X65.38Y114.08
G1X65.17Y114.27
G1X64.99Y114.48
G1X64.83Y114.71
G1X64.69Y114.95
G1X64.57Y115.21
G1X64.48Y115.47
G1X64.42Y115.75
G1X64.36Y116.07
G1X62.19Y115.73
G0X75.97Y115.65
G1Y115.1
G1X76Y114.55
G1X76.05Y114
G1X76.12Y113.45
G1X76.2Y113.19
G1X76.31Y112.94
G1X76.45Y112.7
G1X76.62Y112.49
G1X76.81Y112.3
G1X77.03Y112.14
G1X77.27Y112
G1X77.53Y111.9
G1X77.99Y111.78
G1X78.46Y111.71
G1X78.93Y111.68
G1X79.4Y111.7
G1X80.05Y111.77
G1X80.68Y111.89
G1X80.37Y113.82
G1X79.78Y113.75
G1X79.18
G1X78.97Y113.77
G1X78.77Y113.84
G1X78.58Y113.94
G1X78.43Y114.09
G1X78.31Y114.28
G1X78.23Y114.48
G1X78.18Y114.7
G1Y114.93
G1Y115.12
G1Y115.31
G1Y123.11
G1X80.37
G1Y124.82
G1X78.16
G1Y129.35
G1X75.97Y128.03
G1Y124.82
G1X74.36
G1Y123.11
G1X75.97
G1Y115.65
G1Y115.1
G1X76Y114.55
G1X76.05Y114
G1X76.12Y113.45
G1X76.2Y113.19
G1X76.31Y112.94
G1X76.45Y112.7
G1X76.62Y112.49
G1X76.81Y112.3
G1X77.03Y112.14
G1X77.27Y112
G1X77.53Y111.9
G1X77.99Y111.78
G1X78.46Y111.71
G1X78.93Y111.68
G1X79.4Y111.7
G1X80.05Y111.77
G1X80.68Y111.89
G1X80.37Y113.82
G1X79.78Y113.75
G1X79.18
G1X78.97Y113.77
G1X78.77Y113.84
G1X78.58Y113.94
G1X78.43Y114.09
G1X78.31Y114.28
G1X78.23Y114.48
G1X78.18Y114.7
G1Y114.93
G1Y115.12
G1Y115.31
G1Y123.11
G1X80.37
G1Y124.82
G1X78.16
G1Y129.35
G1X75.97Y128.03
G1Y124.82
G1X74.36
G1Y123.11
G1X75.97
G1Y115.65
M9
G1S0
M5
G90
; return to user-defined finish pos
G0 X300 Y210
M2
I got a message from Darkly labs:
Please ask her to verify what version of the firmware she is running on her machine. If it is 1.8, then she needs to update to v2.0. The instructions are here:
Thank you, I did the update steps… my 0000 arent the same though, see the top line
In the console, type G10 L2 P1 X0 Y0 and press enter. That should reset that.
LightBurn:
G10 L2 P1 X0 Y0
Thank you! They are all 0’s now… now, the Laser looks upside down… I press the button to move it around, and it seems to be reversed? eg if I press the bottom left corner, the laser goes to the top right corner
Go to Edit > Device Settings and move the Origin button to the opposite corner.
