Hopefully quick easy solution
I have a design ive creates for a 16" round (wood). I knw where the center of my wood is. But i was hoping instead of the frame command i gout just tell the crosshairs to move to the center of my round design. Then ill just move the piece to that point. Is this possible?
Yes, if you use the centerfinder tool first to determine your center on your roundel, then you can place your design in LightBurn directly in the center.
Hmm, i thought that was simply to help find the center of your round wood, tile, etc. Ill check it out thanks.
I must not have read your post properly, sorry
…that should work too, why not :wink:
you should just test it on a piece of cardboard and see the result.
Move the laser to the middle of your workspace with “P” hit key.
I like to get it close by eyeball, then use the rubber band frame command to visually center the piece.
Laser on while framing is a great tool, tool.
