Hello together, i´m pretty new in Lightburn (about 28 days since startet).
I just wanted to use the hotkeys to be more efficent. Some hotkey are working like ctrl - for zoomin out. But most are not working like the “Edit Nodes”-Hotkey. Should be ctrl ` on Windows 10. But nothing happens.
I also tried other languages and restarts a few times.
What am I doing wrong?
It’s possible that the German keyboard is actually inputting a different key than how this was designed. I’m not certain in this case but I know that certain characters that might appear the same or similar are in fact different.
The key on a US keyboard for ` is generally referred to as a backtick but is called a grave accent for unicode.
It’s ascii code 96 or unicode U+0060. This can look a look very similar to U+02CB, U+0300, or U+2035. I’m not sure what is on the German keyboard but it may not be U+0060.
I’m not sure if it works but you may be able to type ctrl+alt+(numeric keypad 0060). Not much of a shortcut though.
Just tried to do some research on the German keyboard. I think it should be the same character, but again, not sure. However, it looks like it’s the shifted character.
Are you typing ctrl+shift+` to try to use the shortcut?
If that doesn’t work then it’s possible that you can use PowerToys keyboard manager to create a shortcut that might be able to reproduce this. Microsoft PowerToys | Microsoft Docs
