How can i close these shapes together?
I traced an image and broke it apart so it better fits the 4 panels i need to laser onto. I need to fill these letters but the issue is, due to breaking them apart its not closed so cannot fill. I cannot get this bottom of the letters closed no matter what i try. Any help to make this close so i can fill these is greatly appreciated
i have attached a photo of what it looks like and what im trying to accomplish.
Just post the file itself here, it makes it much easier to see and explain.
Well i’m an idiot and honestly that never occurred to me lol, sorry about that
build a critter sign 3.lbrn2 (166.1 KB)
Hi @mistaken
Providing the original file will help you very specifically here, as @bernd.dk says, but to ensure we have a proper guide for everyone coming after…
The reason these won’t Fill at the moment is that several of the long curves are open paths.
For Fill engraving, each of those needs to become a closed loop — simply drawing one line across the bottom won’t automatically join everything together.
The easiest way is to work through the open shapes individually:
  1. Ungroup the artwork if needed.
  2. Select one open shape.
  3. Go to Edit → Close Selected Paths With Tolerance.
  4. Choose Join with Line and increase the Distance Threshold until that path closes.
  5. Repeat for the other open shapes.
  6. Set them to Fill and check the result in Preview.
Doing them individually is important here, as some of those open ends are quite a long way apart and you don’t want LightBurn joining the wrong shapes together.
And as ever, Preview is your friend.
:sweat_smile: actually @mistaken your project file doesn’t make your intention any clearer…
Should there be a whole A? And the word critter?
What specifically are you trying to do?
maybe this helps lol
the squares are my 12x12 sheets of stock im using. i broke this original image in pieces using the boolean assit tool to make sure what fits on each section is all thats there.
but doing so it makes some shapes not closed which i now need to close.
maybe there was a better way to do the initial breaking? added original file to show what i started with
before assist.lbrn2 (200.6 KB)
maybe this helps.lbrn2 (448.4 KB)
The faster easier way to what you are trying is using the Cut Shapes tool.
Draw a few squares 12x12 and be sure to set the traced shapes to Fill mode before applying the Tool so the cuts are closed shapes.
I’m sure I’m doing something dumb still, but when i select some or all that i need, then select my square last. cut shapes is still grayed out.
I’m sorry i suck at this. This is the first time I’ve struggled to do something in this software and i feel so clueless lol
video shows that it means not a valid shape but i’ve followed and still confused lol
OMG IM AN IDIOT IT WAS GROUPED TO ANOTHER SQUARE I DIDNT SEE!
I got it thank you all so much!
Alright so still dumb… after cutting the A is still open just the same but it does close the d lol
I believe i have found why. You are 100% right that cut is the way to go. I think the A is messed up and I need to work on it a bit more.
Thank you everyone for your help on this!
Didn´t you get this:
i did… the A needs an outline to fill like Build. so in the end the answer is I suck lol. But i added the outline around A and now when i cut, it works right.
