I just bought that small 12x8 GRBL VEVOR 40W Co2 Laser 12" x 8" USB Port Laser Engraving Machine I want to use my Lightburn program It doesn’t connect, Is there a way, or an improvement, a solution I hope! Thank you.
These are pretty much the same animal as a K40.
A controller type supported by Lightburn is the only way you’ll run lightburn on the machine.
Seems like most people upgrade to a grbl type controller and they can then use Lightburn…
Check the controller type, if it’s not supported, then Lightburn won’t help you. You can search the site and the Internet for upgrading a K40 type… should be very similar.
It’s worth an upgrade to run Lightburn.
Good luck
Hi Jack Thank you, The Lightburn controller type that I saw din’t have the right wiring connection for the machine, the ones on Ebay have very little description I want to avoid buying a bunch of them…
Not to simple,
