How can I fix this? Strokes converted to Paths, intersecting lines now clear
Trying to make a topo map, and having an issue with the way that lightburn both (doesn’t) recognize clip masks, and also intersecting paths are not filling.
That’s the nature of the program. If you want those lines to be as one, then you need to combine them in whatever program you’re using to make them.
Alternatively, you can select the intersecting shapes, and boolean union or weld them together in LightBurn.
