I got an error already twice while running a long time burn (not on same spot). I want to see if I can recover from the place it got stuck but I don’t see any indication on the messages. Is there any way to know so I can send again the code from the point it got stuck? Thanks in advance
Already pasted on a simulator the code and I don’t see any issue there.
Waiting for connection…
Grbl 1.1f [’$’ for help]
ok
[VER:1.1f.20170801:K25C-J5EG-FSLQ-E3PK]
[OPT:VL,15,128]
Target buffer size found
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
Project loaded in 44 milliseconds
<Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
Layer C00
Layer C00 Pass 1 of 2
Job halted
Stream completed in 0:04
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
ok
ok
ok
ok
ok
<Idle|MPos:0.000,90.760,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
Layer C00
