How can I tell what my machines max speed is. I was trying to find how to tell in passed forum but could not find it. I have a 15000mw open frame diode laser. Below are my settings from the Console. I am trying to determine what 1/4 speed, 1/2 etc would be.
Grbl 1.1h [’$’ for help]
ok
[VER:1.1h.20190830:]
[OPT:V,15,128]
Target buffer size found
ok
Project loaded in 40 milliseconds
Project loaded in 11 milliseconds
Project loaded in 92 milliseconds
What machine do you have? That would help. You bed is set to 200x200. Is that correct? LM2? When you burn, you’re gonna set it for 1200mm/min or whatever works well. You’re never gonna run at MAX speed. Max, 1/2 and 1/4 speeds are kinda useless. BUT, $110, $111 and $112 set the X,Y and Z-axis maximum rates. Yours are set to 5000 ( X&Y ) Why do you need to know this?
15000 mw Blue CNC Laser Engraving Machine 40"x40". I was working in another program that just used a slider. I noted the speed at 1/4 Power and about 100% speed. I just want to know what the max would be so I can figure from there. I don’t set speed above the machines capabilities. I am just going to use LightBurn going forward.
So it looks like speed max is 5000 so 1/2 would be 2500. This machine did not come with any suggested, speed, power or Z manual height settings.
