My ortur laser only allows my working space to be 15’x15’ and it still has about 2" at the back half that I could be using but when I raise the working space it locks the laser and won’t go that far. Is there a way to unlock this so I can use every bit of space I’ve got?
Your laser should allow for a space of 400x400 mm which is almost 15.75 x 15.75 inches.
I suggest you switch to mm for units and then go to Edit->Device Settings and change your working size to 400x400 mm.
