Hi, I have the version 0.9.24. How can I set a different destination on the laser head when the job is finished (final point).
Thank you.
Thank you.
Your profile says that you have a Ruida based machine, in which case you cannot. This is simply a limitation of the controller. It will always return to home - whether that is true home or whatever you last set the user origin to. So that’s probably the answer for you - use the controller’s user origin setting.
If you have a gcode based machine you can in device settings:
Thank you for the quick response to my question.
