I have a twotrees TTS 10 Pro laser engraver and i want to use it to mark plastic eartags like the image attached. I use lightburn for it but i don’t know how to achieve this. Can anyone help?
I’m not sure if you can achieve the effect shown with a diode laser, but it needs to be tested.
The logo itself shouldn’t be a problem, or is this where you’re having problems?
I want to know if it is at all possible to mark plastic with this type of laser or not. Two trees say it’s possible but they didn’t give any instructions on how to achieve it.
That was most likely engraved with a galvo laser. 1064 nm laser will give that nice grey effect in plastic, your diode laser will tend to dig into plastics and melt and or remove materials. So you will end up with a much different effect.
See here:
