How do I fix Alarm 2
After clicking start, the laser starts to move then stops and Alarm 2 pops up. I have included pics of the project and the error.
This depends on where your laser is positioned ad the moment and what starting position you selected. If you have “current position” as starting position, the warning from the laser screenshot can be ignored.
To get rid of the Alarm 2 error, you need to first home the laser and then send the job. If it’s smaller than the workspace, it should run fine with any starting position (except user origin).
The laser “homes” when I turn the machine on. The “job origin” is bottom left corner and the “Start From” is Current Position.
Try switching to absolute coordinates.
Check the move window after the start then. What position does it show at 0,0 position?
Just tried and works fine. Thanks
Please explain and then add a solution to help others that may have this problem.
I made the change to absolute coord and it works now.
