How to select the acrylic material
You have to test this out for yourself. Every laser system is different. Once you find the correct settings for your machine, write them down for reference. You laser manufacturer might have a list for you with some start settings, but you still need to try it yourself. Sorry that I couldn’t be more help
with a diode laser you can engrave this material only if is total black or is surface painted
Acrylic is transparent to your led laser. You will have to use ‘colored’ acrylic to block the beam frequency.
There is a materials library in Lightburn, enter the data there…
