hello, how to I set the maximum size for my machine. when i set up a simple circle to cut out of 1/16 in wood, the laser goes up to the left had corner and makes a hora able sound, then goes down to the right hand corner and does the same thing,the n it makes the circle.
I need to set it up so the circle stays in the center.
You can make corrections using the Machine Settings window. I recommend you set max X and Y travel to 5mm or more LESS than what the manufacturer advertises for the work area. This will help keep from banging into the rails.
