how do I shorten my Y axis? I added a z axis adjuster and now the laser hits the frame after the job is completes and homes down to the opposite end.
- If the Z-axis adjustment blocks your limit switches for homing then relocate your Y limit switch to accommodate the mod
- After homing, determine the amount of max Y-travel now available to you by jogging as far as possible without crashing. Use “Get Position” in Move window to determine new Y size.
- In Edit->Device Settings enter new Y value
- In Edit->Machine Settings change $131 to new Y value (this needs to be done in mm for units)
I suggest you stick to mm the entire time that you do this. You can switch back to whatever other unit after the adjustments are made.
Looks like I need to reduce to 440mm from 460mm, I can’t find in machine settings where to do that unfortunately.
Look specifically for the item that correlates to $131.
If you can’t find it in Machine Settings then you can just input the value manually in Console:
$131=440
I found it in console and it works, Thanks for your help
