How do you correctly save and load a project?
When I try to load a saved file, it doesn’t recall the correct power and speed settings.
Are you clicking Open or Import? Open is the second icon from left, Import is the far right icon. Open should load your settings, Improt will only load the graphics wihout any settings.
The fourth icon. Square with a left pointing arrow.
That’s Import - It will Import vectors from another file into your current project, but will not bring in the settings.
Use Import if you want to pull shapes or images from another file into your current one, but use Open to load a project file with all the settings intact.
Now it makes sense. Thats the information i was missing. All works perfectly now. Thank you
