How do you get Lightburn to read files stored on my Topwisdom 50 watt laser?
I have a Ruida, but Lightburn doesn’t read them from the controller that I know of. The only way I know of getting those stored files is through the controllers console to a usb stick.
I don’t know if it’s any different from your Topwisdom.
Good luck
Thanks for the reply. I had thought that the u plug on the Topwisdom connected to win 10 pc would allow access to the Topwisdom files apparently, that doesn’t work. Any other suggestions would be welcomed.
Most of these have two usb ports, the pc the other is to read/write the controller files to a ‘u-drive’.
The Ruida, from the console, will copy an internal file to the ‘u-disk’ along with reading a file from the u-disk, but it’s not an access port. It’s got the specifications for a usb, but the code of the controller is limited.
Lightburn has a ‘run RD file’ and ‘save RD file’ in the laser window. I’ve never used them…
Good luck
