I am aware there are multiple formats for Lightburn files, .lbrn and .lbrn2. Will there be a new format for pages? As a designer, how do you save a file using pages that will be safe to open for someone using an older version of Lightburn? Currently when I open a file saved in 2.2 with multiple pages in 1.7, it dumps all the pages on top of one another, jumbling all the pages tongether.
Obviously 1.7 cannot handle Pages. If you are sending files to a customer, then you work with the lowest common denominator. If you save a file without Pages, then v1.7 can import it, right?
I doubt any software company will recompile their old versions to install new features.
To clarify, I’m not asking for any changes to older versions. I’m asking whether 2.2 can save a multi-page project in a way that opens cleanly in older versions.
I sell designs created in LightBurn and offer them as .lbrn2, .dxf, .ai, and .svg. Not everyone will update, so if I build a project using Pages, I need a way to save a copy that opens cleanly for customers on older versions. Right now, opening a multi-page 2.2 file in 1.7 stacks all the pages on top of each other.
Is there already a workaround I’m missing? If not, I’d like to suggest something for 2.2 while it’s still in Early Access, such as:
- a “Save for older versions” option that lays the pages out side by side on one workspace, or
- an option to export each page as its own .lbrn2 file.
Good ideas - mind posting them over on lightburn.fider.io?
I have been giving it some more thought and I sent this idea to Chris and I think it could be “simple” coding fix that happens in the background and no one will ever be the wiser and files saved with Pages will work with any version of Lightburn, but not as individual pages in the legacy versions.
Subject: Re: saving options??
I’ve been thinking about how this could work, and I think there may be a fairly clean solution that doesn’t require any changes to older versions at all. Everything would happen inside 2.2.
THE PROBLEM
Right now, every page’s shapes are saved at the same positions in the file. Page 1, page 2, and page 3 all sit in the same 0 to 610 mm area (using my Lasermatic’s 610 x 396 mm workspace as an example). An older version doesn’t know pages exist, so it places every shape exactly where the file says, which puts all the pages on top of each other.
THE IDEA
When a new page is created in 2.2, give it its own permanent home position, offset by the width of the workspace:
- Page 1: home at X = 0
- Page 2: home at X = 610
- Page 3: home at X = 1220
- And so on, adding one workspace width per page
The shapes on each page would be stored at those real positions in the file. The offset would be internal only. On the design side in 2.2, every page would still display from 0, 0, exactly like it does now, so nothing changes for anyone using pages.
HOW EACH VERSION WOULD READ THE SAME FILE
- 2.2 (and anything newer) knows about pages, so it shows each page on its own tab, displayed from its own 0, 0. The user never sees the offsets.
- Older versions don’t know about pages, so they simply place every shape at its real saved position, which is what they already do. Because each page has its own position, the pages open side by side in one long layout instead of stacked on top of each other.
One file, one set of data, and it opens correctly in both.
WHY I THINK THIS WORKS
- No changes to older versions. Older versions don’t need to recognize anything or follow any new instruction. They already place shapes where the file says. The fix is entirely in how 2.2 stores positions.
- No extra save option or special export. Designers wouldn’t need to remember to save a separate legacy copy. Every multi-page file would already be legacy-friendly.
- No overlap. Since each page’s contents fit inside its workspace, and each page starts where the previous one ends, pages can’t overlap. They may butt up against each other, but that’s fine.
- The workspace size is already known. 2.2 already knows the dimensions of the laser the file is being created for, so it has the number it needs for the offsets.
A customer with a smaller bed might see some pages extend past their workspace, but that’s harmless. Nothing overlaps, and they can drag each page’s designs into place.
I’m not a coder, so I’m sure there are details in the file format that I can’t see, and the developers will know best whether this fits how things work under the hood. But from a user’s and designer’s point of view, it would solve the problem for everyone, without anyone having to do anything differently.
If this approach doesn’t fit, a “Save for older versions” option that lays the pages out side by side would still be a big help.
I sell my designs as .lbrn2, .dxf, .ai, and .svg, and not everyone is going to update. I’d love to be able to use Pages without cutting off customers on older versions.
Great - but please do post this over on Fider, so we don’t lose track of it
Give us the link to the Fider posting so we (I) can vote on it. This also allows anyone reading this thread to easily find it as other Fiders are added.
