# How long does a diode laser last?
**URL:** <https://forum.lightburnsoftware.com/t/how-long-does-a-diode-laser-last/68852>\
**Category:** LightBurn Hardware Compatibility\
**Created:** [June 10, 2022, 4:48am UTC](https://forum.lightburnsoftware.com/t/how-long-does-a-diode-laser-last/68852 "2022-06-10T04:48:14Z")\
**Showing post:** 2
**Author:** ![berainlb](https://forum.lightburnsoftware.com/letter_avatar_proxy/v4/letter/b/85f322/32.png) [@berainlb](https://forum.lightburnsoftware.com/u/berainlb)\
**Post date:** [June 10, 2022, 4:59am UTC](https://forum.lightburnsoftware.com/t/how-long-does-a-diode-laser-last/68852/2 "2022-06-10T04:59:17Z")
I’d first suggest thoroughly cleaning your lens to make sure the reduced power isn’t the result of a dirty lens. The act of burning releases a lot of gases that can accumulate as a residue on the lens.
If you’re lucky that will return power back to normal. If not, it’s very possible as you say that the diode has degraded to the point where power loss is very noticeable.
I suggest you read this Topic for some additional perspective:
> [@100% power rumor](https://forum.lightburnsoftware.com/t/100-power-rumor/64586/4):
> There’s nothing magical about the 100% number that damages diodes. However, there are reasons for running below 100% duty in order to increase the potential diode longevity. A few things to consider: Diodes degrade from the moment you start using them. Even at lower duty loads. They are in constant degradation. The variable then is rate of degradation. Diodes themselves have manufacturing variance that can increase or decrease their actual working lifespan vs statistical life expectancy. DOA …
_[View the full topic](https://forum.lightburnsoftware.com/t/how-long-does-a-diode-laser-last/68852)._
