How to add the default library
I need to load the default library.
Please guide me how to add the default library.
The documentation is not clear enough.
https://lightburnsoftware.github.io/NewDocs/MaterialLibrary.html
There is no default library, you need to create your own with your settings for your particular machine.
how can i create library for Ortur Laser Master 2 .
I am new to this.
Please help me
Click ‘New’, then ‘Save As’ and give it a name. From there you create a material entry by copying it from an existing layer in a design. If you have a project with a setting that you know works for 1/8" birch ply, for example, you could load that, select that setting, then click ‘Create new from layer’ and enter the information for it.
