I’m new to LB and have a question. I have an Ortur LM3 with the extension. When I start LB it shows my entire work area. I usually import images into LB and it drops them right in the middle of the work area. So I’m constantly dragging and zooming. Is there a way to change the drop point and zoom into location closer to 0,0? - Thanks
Here are two options:
- Zoom closer to the area where you want the image. Then import.
- Drag and drop image from File Explorer to LightBurn workspace where you wan tit.
