Newbie question.
I purchased Wecreate vision plus their conveyor which connects via the rotary port.
I downloaded their lightburn config file and installed. Then looked to increase the workspace in lightburn but couldn’t find a way to do it. Contacted Wecreat support and they told me lightburn does not support it.
Since I purchased lightburn I want to use that for all my work. So is there a way to configure the workspace for the conveyor or is this an enhancement request? With the many conveyors on the market today I would have thought this a high priority especially when you consider how small the working area is on most popular lasers and the inevitable need to add a conveyor.
Welcome to the forum Nigel.
As a start check this link:
https://support.wecreat.com/hc/en-us/search?utf8=✓&category=10991877389071&query=CONVEYOR
Then duplicate the laser device and name it Vision Conveyour:
Enable Rotary and set Circumference to 3150mm (Lightburn max currently)
Test Chuck and Roller type, A and Y axes. If this work but the output is compressed in Y you may have to calculate a ratio for the correct output.
