Consolas - standard windows font I believe
Was confused about the text area part. I will play around with it.
Is this using circular array alone or in combination with variable txt window?
Any time you use any of the variable text types (e.g. serial, merge/csv, date/time, cut setting) the options in Variable Text window come into play.
Where/how did you get the arrows and lines in the center?
Make triangle, couple of rectangles, weld, duplicate and mirror.
