How to darken lines of imported svg/dxf items
The lines for imported svg/dxf elements are so faint it is very difficult to see them on the work table layout and even more difficult to see when camera image overlay is used. How can I make these lines darker or more distinct? Same is true for draw tool items. There is an adjustment for grid contrast, but not drawn/imported elements.
As far as I know there really isn’t a direct way of changing this.
Some potential strategies:
  1. Use more easily visible Cut layer colors
  2. Toggle “Fade” in Camera Control window
  3. Increase application scaling
Perhaps I found the answer. When items are placed on a layer and then selected (on) to cut/fill the lines become distinct. When not selected to cut/fill the lines are ghosted. I had arranged several cut, but turned the Output toggle under cuts/layers off until I was ready to cut. This left the lines ghosted while trying to align. If I had turned the Output for the layer to on, they would have been clearly visible.
Thanks for your response, as your suggestions helped as well.
