How to delete overlap in two shapes
Hi, this may seem like a basic question but I’m having trouble deleting the overlap on two shapes, I’m pretty new to lightburn and like to see if I can do things by just playing but this has me stumped.
Here is the file I’m working on, I just need to remove the tips of the stars that join the pad so I can cut the whole shape without it falling apart.
Paw with stars.lbrn (196.3 KB)
Select a paw pad and the star inside it, press control + B and a panel will show up with the options for changing the 2 objects. Hover your mouse over each the 4 methods to see what it will do. Press the method you find works- then press OK, it will cut the selection you made.
Thank you Patrick, your a diamond :+1:
