How to divide a circle into four quarters
(KENNETH HARSHMAN) #1
how would I divide this circle into 4 pieces thank you
(Rick James) #2
That depends on how the circle was created. If you draw with LightBurn, select the circle, then ‘Arrange’=>‘Break Apart’. This will divide the circle into four equal quadrants.
If the circle is an imported vector, ensure it is ungrouped from anything else and use ‘Node Edit’ to break where you’d like.
(KENNETH HARSHMAN) #3
thank you i will give that a try
(system) closed #4
