How to insert an existing barcode file into LightBurn?
Hello,
I would like to insert an existing barcode file into LightBurn.
I have the following questions regarding this:
In what format must the file be? Should I use the “Open” or “Import” function?
What are the next steps?
Thank you!
As a rule, only lbrn(2) files can be opened, everything else must be imported.
If you cannot create a new barcode with your information directly with LB code designer, I will import the existing barcode as a graphic, test it with a phone and adapt it to the project.
