Marv4545
(Marvin)
1
Hello, is there an opportunity to keep the steppers on when a engraving cycle is finished?
Because of the strong cable sleeve one axis is moving every time after a program.
A workaround could be to HOME the laser every time a program starts. Would this be possible in lightburn?
Thank you
Marv4545
(Marvin)
2
For the workaround I have found a solution.
Device settings → GCode → enter $H at start GCode
raykholo
(Ray Kholodovsky)
3
What is the $1 setting in Console?
Marv4545
(Marvin)
4
Its 200. So if I set this up to like 60.000 its 1 minute and shouldn’t move?
EDIT: 1.000 is the maximum I can type in, but as soon as I write and close the window, it sets back to 232
That number is in milliseconds, not seconds. Setting it to 255 means the motors stay locked.
Marv4545
(Marvin)
6
Awesome it worked, thank you!
system
(system)
Closed
7
