Thanx for sharing. So what setting did you end up using so that the photos did not show any scan lines?
Sas
Sas
Ha I haven’t gone back to this, it takes to much time and the results are a bit unpredictable I may do some more experiments later when I get time. I’m not sure if the scan lines are a resolution/dithering problem or a coating issue probably both, like I say I believe its better to do this with a small Diode laser, the CO2 laser frequency isn’t the best for this. I may be wrong but from what I’ve seen of youtube it seems to work really well with those little Diode ones.
For consistent results how you lay paint down could affect a lot I think. Irregularities in the outcome could be human error in applying the paint fractions thicker here and there. This is interesting!
Plus the tile must be cleaned with Lacquer thinner and the then one light even coat of flat white and completely dried
