Is it possible using lightburn to split a file in to two separate files in order to make a larger project from 2 seperate pieces or whatever you are wanting to do?
Not easily in the way you are thinking. Vector art, depending on the complexity, could be split using the ‘Node Edit’ and Boolean tools. LightBurn does not currently have a tool to split bitmaps.
Example of split vector using a thin rectangle and Boolean ‘Subtract’.
Thanks for the info.
I do this frequently with maps I need to tile. It’s done in Illustrator because they have all the tools needed to pull this off successfully.
