How to prevent lines to be cut
I am cutting model airplane wingribs. I dont want the laser to cut the building tabs. How can I stop the laser from cutting that part of the airfoil?
If grouped ungroup first then set the part to another Cut/Layer set to no output.
Vill try that!
Thanks
Ok I described not clear enough. I dont want the laser to cut the small part that joins the wingrib with the building tap. I need to block the laser form cutting those 20 mm of the airfoil. But the airfoil is a block line and I cant find how to just cut away the 20 mm
Maybe this.
Add Tabs - LightBurn Documentation
Good!I will try this
Thanjs!
