How to reduce lines when engraving a coated tumbler
Using a Ortur laser master 2 pro with the chuck rotary,
What dpi/lpi to use is dependent on may things…
Laser Everything’s video of how to photo engrave may not sound like what you want, but it’s the best for determining the proper dpi for any laser with any material. He does this on a fiber, but the idea is the same no matter what machine you use… Suggest you take the time to watch it. The information will benefit you for your entire laser life…
Good luck
