How to reduce or speed up traversal moves?
Hello. I use to do shapes like the one in the pictures where I need to fill areas around the shape.
  • They are the same shape (soit does not matter if I set “fill groups, all or shapes at the same time”)
  • I don’t want to use Offset fill because I want straight lines (in this case, interval is 0.5)
Here is a video of the actual problem: https://amaroa.es/help/heart.mp4
I waste too much time traveling without firing.
Thanks.
2 possible suggestions:
  1. Enable and increase “Fast whitespace scan” in Edit->Device Settings
  2. Use Flood Fill in Advanced Tab of Cut settings. Note that this may compromise quality and leave a visible seam where the engraving areas meet.
As @berainlb suggests. :slight_smile:
1 -
2 -
Thank you both!
