I have a design with three layers how can I run just the cut layer when all 3 layers are sent to machine. It already did the fill pass and 2 line passe to cut but need to just run line pass another time.
uncheck the box marked output in the cuts list and it will run only those checked.
If you right-click the column header above “Output”, you can turn off, on, or toggle all layers quickly. Not a big deal with only a couple layers in the project, but useful if you have more than a few.
That worked thanks
